I love my super A and the 140 is just a newer version. One would hope any changes they made to it were all improvements. They do have a little more power which is always a plus.
I have no direct experience with the 140, but I'm guessing you'd be happy with it given you check it over as you would any tractor for obvious cracks, leaks, exhaust smoke, and odd noises.
They're light tractors, relatively speaking, so tires are real important. The better the tires, the happier you'll be when you're in the dirt.
I'd go with front and rear wheel weights, factor having to buy them into your total price if the one you're looking at doesn't have them.
And speaking of that, implements tend to be much cheaper when you buy them with a tractor instead of trying to accumulate them later. There are lots of parts out there, but the shipping will kill you.
The 140 was designed to do exactly what it sounds like you're doing. So its' a great choice. Of course, anything more than a few acres and you start needing something larger. How big of an area are you planning on working?
Also, if it's your ONLY tractor, you might be happier with something a little larger too - unless you're sure it's only job will be what you describe here.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
