140 and similar models are excellent for 1 row cultivating, need to have both front and rear cultivators. I am referring to the factory cultivators. Spent many hours cultivating with one. If you have the fast hitch, you will have to take that off if your plants have any height, so it won't drag on the plants. Factory type rear cultivators mount so that you won't need the fast hitch with them. Like some other reply's, there are newer type rotary cultivators that can be adapted to the tractor to make it a multiple row cultivator. Also if you can adapt the rotary cultivators you can increase your ground speed. Important to decide what cultivator you are going to use before you plant , in order to get row width right to use the tractor. Have fun
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
