What is the best cultivating tractor? First off, it depends on what you are planting, how much you plant and how you plant it. I assume you are talking about doing close cultivation, as most most rip-up-the-centers cultivating has been replaced by weed killer.
To cultivate multiple rows requires planting multiple rows. You aren't going to plant one row at a time and get the spacing accurate enough to cultivate more than one. Two-row also requires twice the tooling and twice the work to change set-ups from one crop to another. Close culitivation requires close observation. Therefore ANY front mount cultivator will be better than ANY rear mount. You need an unobstructed view straight at the row.
Throw those criteria together, the best 1 row cultivator is the Super A through 140 series. I leave the old A out of this list because of no hydraulics and harder to find/use implements. Fast-Hitch (100-140) is nice if you use the tractor for other implements but irrelevant to cultivating. Second place is the Cub. Lower power, less speed flexibility and the single circuit hydraulics move it to second place. A lot of implements are easily found for either model. A begrudging third goes to the Allis G, competitive with the Cub but more costly, harder to find implements, often hand lift, hard to find parts. There are a number of Super A "clones", one batch from the 1950s, another from after the 140 was discontinued. I didn't consider them, as production numbers were low and they typically had their own problems.
If you can and want to go to 2-row, first place goes to the B or BN. Granted, it lacks hydraulics, but the work visibility is superior to anything with the seat in the middle. You also sit lower then you do on a C or larger. Better to look forward and a little down than sideways and way down. I give second place to the C and Super C. Anything bigger isn't needed for 2 rows.
Specific question about 140:
Biggest problem to look for is if the entire tractor is simply worn out. They were so good that owners just kept using them. Check for wear in the pedals, the steering, the shifter etc. Specific problem/abuse areas to check are cracked housings: mounting flanges at front of engine block, front bolster and the top of the final drives. Look at the studs where the drawbar mounts to the final drives. Check the left side of the engine block (high, behind carburetor) for freeze cracks. Drive it in each gear and listen for transmission noise.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
