The problem you'll have in squeezing wider tires on there is, they will look more ballooney than cool.
You need to have a wider rim to allow the tire to spread out. 12.4x38 belongs on an 11" rim I believe, but is commonly installed on 10" rims.
The coolest tire on an H is a 15.5x38 on a 14" rim, because the 15.5 is the same diameter as the 13.6, just wider. Unfortunately that's only an option if you've got an unlimited budget because you need rims and tires. Of course you could widen the rims yourself if you're a decent fabricator.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
