Posted by mkirsch on April 18, 2012 at 06:49:41 from (64.80.110.74):
In Reply to: Front tires posted by Pete7 on April 18, 2012 at 06:35:25:
Going from 6.50-16 to 6.50-15 will only lower the nose 1/2". You'd need to go to some real skinny 15" tires like 4.00-15, or to 14" rims or even 13" to get any real nose-droppage.
Putting bigger tires on the back saps the tractor's power.
If you look at the 40/60 series as a whole, the tractors tended to sit nose-high with factory size tires on them anyway. We had a 560 growing up and it just BARELY sat level with new 16.9x38 tires on it. Factory was 15.5x38 which are low-profile tires to begin with.
Besides, tires and rims are expensive so frankly I would learn to like it.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
