Posted by Haas on May 16, 2012 at 18:21:28 from (75.203.16.34):
In Reply to: belt pulley seal posted by truckerlary on May 16, 2012 at 18:07:53:
You do not need to remove the belt pulley assembly from the tractor to replace the belt pulley seal. Remove the bolts that hold the flange (which has the shaft seal in it) to the pulley housing. You can then slide out the pulley shaft assembly which has two bearings, the mounting flange and the bevel gear that drives the pulley shaft. You will need a shop press and bearing splitter to remove the gear and two bearings from the shaft. Then the flange and be slid off the shaft and the seal replaced. Be aware there are shims between the flange and the pulley housing which set the gear lash. So be sure to put the shims back like you found them. There is not a gasket there, so everything must be perfectly clean to minimize the possiblity of leaks when you reinstall. Also when you remove the shaft assembly, be prepared for the oil that will come out. There is not a drain for the pulley housing so the oil drains (only a quart of so) out when you pull the shaft assembly out. The pulley assembly receives it's oil from the transmission, but it's a good idea to add a quart of gear oil to the pulley housing through the fill port in it when you reassemble.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
