Posted by AG in IN on June 15, 2012 at 13:49:45 from (67.236.106.64):
In Reply to: 1939 F-20 worth posted by mkirsch on June 14, 2012 at 05:35:48:
sdmike said: (quoted from post at 21:09:06 06/15/12) It is not a "farmer engineered" post hole digger.:-) I was told by my FIL many years ago it came with the tractor when his dad bought it. I have never seen another post hole digger like it. Mike
It's definately not farmerized. I have a similarly constructed post hole digger on a Farmall H. Mine says "ATOM MFG. CO. MOLINE, ILL" on the top of the gearbox. Mine doesn't have the handwheel, it has a really long hydraulic cylinder to raise and lower the auger. It has a 2-way hyd. valve that the control rod goes to a shorter bracket where your handwheel is. The way it pivots on the front and the upright supports are the same. Looks like the same angle iron and the same adjustment lever along the side of the tractor. Is the shaft that goes through the gearbox hex-shaped and is there a thrust bearing at the top?
I always wondered if the operator could drill out a tunnel with it.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
