Zach - If the points are not making contact and grounding when closed, the voltage readings you observed are normal.
To verify try running a temporary jumper from the distributor primary terminal to a good ground. Now turn on the ignition and take your voltage readings again. You should see 12 volts on the ign side of the resistor; approx 5 - 7 volts on the coil side of the resistor and the resistor side of coil primary; and 0 volts on the distributor side of the coil primary. (Don't leave the ignition "on" longer than necessary to take voltage readings - to avoid overheating the coil and resistor).
I'd recommend replacing the points/condenser and see what you get.
Incidentally if your tractor is negative ground, the coil + SHOULD be wired to the resistor and the coil - to the distributor. However the coil will work fine with the connections reversed.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
