A ballast resistor has very little resistance when it is cool (very little current passing through) so a volt reading will show close to 12 v . Now if the points happen to be closed when you turn on the key then the resistor will get hot, ohms will increase, voltage will drop. Last but not least, some starter solenoids have an extra terminal that is only energized when the starter is engaged. Hook that terminal to the coil side of the resister.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
