The resistor only "resists" when current is flowing. With no current flowing your readings are normal. Think of current as water flowing and the voltage as pressure. With no water flowing, pressure can build up even through a small restriction.
The battery + should be hooked to the coil + and the - on the coil to the distributor. Grab the end of the distributor where the rotor goes and push/pull on it to see how much play there is. Occasionally you find one with so much play that it defies setting a usable points gap. Should still generate a spark at some point.
Frankly I would just leave off the resistor in this case. It's a little harder on the points but you will get more fire and helps engines with weak compression, oil burning etc.
Hook it up without the resistor for your testing and you can incorporate it later when you do re-wiring.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
