If you do leave the resistor off on a 6V coil, just be careful never to leave the ignition on while the engine is not running for any extended period. If the points are closed, the coil will overheat and possibly explode, spraying very hot oil over the side of the tractor and anything else in the vicinity. "Ask me how I know."
This post was edited by TheDurk at 13:31:53 06/22/12.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
