PTO shaft in the center housing will just come out with the housing. From the seasonal disconnect forward. Use dowel pins on each side and don't forget the housing retaining bolt up in the seasonal disconnect hole. 9 bolts total center housing to trans. housing. To remove the worn PTO drive shaft in the front. Remove the clutch operating cross shaft and the three bolts in the housing the release bearing slides on. Screw a slide hammer in the clutch shaft, its 3/8 coarse threads. When the shaft comes out the pto shaft with gear and housing comes with it. Hard to say if it was run in low t/a until you remove the top cover on the center housing and see what the t/a release bearing and t/a clutch and parts look like. IF the t/a clutch is intact the second shaft lever or back one on the t/a housing will have tension on it trying to turn it clockwise if in low. You need a manual to tackle the whole job.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
