Posted by charlie M on June 26, 2012 at 16:53:09 from (74.34.216.81):
I'm getting ready to put the electrical system back on my A. It had one at one time but all that is left now is the starter. I'm wondering if there is a "right way" to do it. I've seen the deal that mounts to the starter and you pull on a rod to start it. This tractor had a solenoid mounted under the gas tank with some sort of switch up by the operator. All I need to buy is some battery cables and either the solenoid or the starter switch.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
