Posted by Matt E. on August 22, 2012 at 05:46:40 from (108.66.162.71):
Getting closer to hearing it run, I'll try not to flood you with pictures but have a few.
There is very little paint left on the tractor but the tin was in perfect shape except for the grill. Amazingly the inside of the gas tank is spotless. This is what it looked like before we tore the tractor down.
It wasn't bad but needed a little work, the top and bottom were good.
Half done, on to the other side.
There, that's not too bad and her teeth are straight now! Not perfect but pretty good. I had a punch that fit just right in the channels and I was able to save the screen as well.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
