Posted by Bob M on October 05, 2012 at 10:54:01 from (74.67.191.50):
In Reply to: Free Play? posted by BigTone on October 05, 2012 at 10:16:07:
Anthony - 1-1/4" measured at the pedal has always worked for me.
Keep in mind pedal free play is not real critical so long as: 1) The throwout bearing retracts free of (does not touch) the clutch fingers when the clutch is engaged AND, 2) When depressed, the clutch disengages fully (tranny input shaft stops turning) an inch or two before the pedal "hits bottom".
This post was edited by Bob M at 20:14:08 10/05/12.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
