Posted by gene bender on October 30, 2012 at 06:34:26 from (207.177.56.85):
In Reply to: farmall super a year? posted by daynee on October 30, 2012 at 06:00:14:
You dont have a Super A You say the tag is gone from the left seat bracket so look under the front spark plug behind the throttle rod there will be letters followed by numbers. It should start with FAA. There are cast codes also to tell about when the tractor was built.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
