Thanks for the replies! Well, not too sure about the Diesel McCormick-Deering on steel; never seen one here before. The AW-6 has had various modifications to it. Several of the decals are not standard. It has a second glass water trap under the petrol tank in addition to the one under the kero tank. The grille and heat shield have been chrome plated. It has been fitted with Lucas 700 headlamps, which are 7" in diameter in place of the Lucas L-H-O originals at 5¼". It has converted to 12 volts and fitted with an alternator. It is the last month of Spring here and due to the higher than usual rain fall and the fact that Lake Goldsmith is not far East of Ballarat, there is plenty of green grass out there. Didn't see one kangaroo though! There were plenty of steam traction engines as well, most built here, but several from England. Attached are three pictures of one made in Ballarat. It is a Jelbart.
This post was edited by SadFarmall at 22:29:11 11/05/12.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
