Posted by farmallhal on November 20, 2012 at 11:34:06 from (76.4.176.113):
What is the proper thread sealer to be used in the fuel system like on the fuel shut off/sediment bowl that screws into the bottom of the fuel tank? I believe that plumbers teflon tape (the white stretchy stuff) is fine for water and anti-freeze applications but I'm hesitant to use for fuel applications. What is generally used for fuel/gasoline applications on our tractors? Thanks much for your suggestions, Hal.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
