Posted by BoonvilleKid on November 28, 2012 at 20:59:55 from (24.206.167.192):
On one SC I have removed the starter and observed the ring or flywheel gear. This SC has 6V battery and generator. The teeth on the flywheel gear look like new. On another SC, I removed the starter and looked at the flywheel gear. This SC has 12V battery with alternator. The front of the teeth on the flywheel gear are badly worn down. It appears that about 1/4 of the width of the teeth has been chewed off. Is this condition due to using a 12V alternator/battery on a 6V starter?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
