Posted by pete 23 on December 10, 2012 at 11:20:55 from (74.32.238.2):
In Reply to: Farmall 560. posted by Kevin B from Illinois on December 10, 2012 at 05:29:02:
That will make it turn shorter but it will mess up the steering geometry. You realize that the inside wheel always has to make a tighter turn than the outside wheel or the tires slide sideways on a tight turn. There was a short turn kit made years ago. Installed a few of them. They took original arm on wheel and put a different bend in it and then added an adaptor to the steering arm in center to change the throw. It worked but was not engineered as well as it should have been . They used straight drilled holes in adaptor which should have had tapered hole and then they used plain bolts in the tapered hole in center steering arm so it was hard to keep them tight. I made a tapered spacer to overcome that problem.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
