A ballast resistor can be mounted ANYWHERE will fit and and it will work fine. The extra length of wiring won't hurt a thing. Just don't stick it where resistor heat will be a problem - like on the gas tank(!)
I like to hide the resistor on a bracket fastened to a rocker box bolt so the resistor is positioned above the rocker box. It's hidden away nicely, and it has plenty of cooling airflow.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
