Sort of in line with Bobs concern about heat dissipation and airflow, I like the metal mounting bracket attached to a good heat sink like a larger bolt etc that goes into heavy metal versus any thin screw into sheet metal etc and where air is circulating. If youre drawing 4 amps and it drops 6 volts (typical) thats 24 watts of heat that needs dissipated......I prefer they be used between the IGN switches output and the coils input....
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
