Posted by big a on March 08, 2013 at 17:03:51 from (70.198.2.59):
In Reply to: Looking at a 756 posted by picassomcp on March 08, 2013 at 16:42:03:
Sat lots of hours on a pair of 756's. loved them dearly.
First thing to do IMHO, would be, with engine cold, as in not started for a few days, crack the oil plug loose, and check for any antifreeze coming out past the threads. The Neuss engines were problematic for that.
Next, see how it starts cold, if injection pump is weak or not timed properly, they can start hard, also if down on compression due to wear. Valve recession can cause this too.
Don't be too alarmed if it slobbers fuel out around the exhaust manifold, common if they idle around too much, especially in cold weather.
Check shifters and linkage for proper adjustment, and all the other items just like your 706.
With decent care, that engine should have plenty of life left.
Oh yeah, stay on top of fuel filter maintenence. Seen lots of those inj pumps trashed by water damage, especially on machines that sit unused a lot.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
