Posted by Rod Kuecker on April 19, 2013 at 17:35:32 from (74.44.35.165):
In Reply to: F 20 gas tank posted by SDE on April 19, 2013 at 17:24:31:
All F-20 gas tanks had 2 fill holes, tank is divided off, with rear fill is a much smaller tank for starting gas, & the top fill is for the kerosene for running after tractor is warmed up. Kerosene was much cheaper than gas, back in the ol' days. If you see a F-20 tank with only fills on top, that is from a Farmall Regular, they had a seperate gas starting tank. If you need a F-20 tank, get back to me, probably got 10 of them here.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
