Re: SC starter ring-gear replacement
Posted by Bob M on May 13, 2013 at 07:54:29 from (67.240.170.161):
In Reply to: SC starter ring-gear replacement posted by BoonvilleKid on May 12, 2013 at 23:01:17:
Like the others point out, the hard part is splitting the tractor. After removing the flywheel replacing the ring is a snap:
1 - Heat the old ring gear lightly - a propane torch will be sufficient. The warmed gear will slip easily off the flywheel with a few light taps.
2 - Heat the new ring gear 15 minutes in a 400 deg oven. (Tip: this best done while your wife is off somewhere.)
3 - Now set the hot ring gear in place on the flywheel. It will grab tightly as it cools.
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
