Posted by pete 23 on June 10, 2013 at 10:25:41 from (74.32.230.205):
In Reply to: HELP! 966 posted by Allan In NE on June 10, 2013 at 05:26:54:
You look through the half inch pipe plug hole on rear side of front cover. Mark on hub to timing pointer. Will not be tdc, rather about 18 degrees btdc. Can be cyl six or one. I can readily tell if pump still works by removing three bolt plate , lines to injection nozzles at pump, all other lines still hooked up, open throttle, turn pump with ratchet and see where fuel exits head fittings. I have never seen a factory cab you cannot get at timing marks. Some not easy but can do. Have to take off that corner shield.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
