Posted by Mike Van on July 03, 2013 at 03:20:21 from (24.151.25.186):
In Reply to: 574 hydraulic leak posted by Bill Allis on July 02, 2013 at 14:32:32:
Bill, top of the case, under the top cover between the dash & the seat I found two spots mine was leaking. These were round holes that had a rod through them. You'll need to power wash this place to find them, run the tractor around for a few days without this sheet metal cover on, you should be able to see these places weeping oil. I cleaned mine up, and put a good blob of epoxy on the top of each rod, no more leak, three years now.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
