Are you sure that there is no externalblockage of the radiator matrixwith dust &debris??
Inside the radiator is the water circulating correctly or are there blocked tubes?? You can find these by running your hand over the matrix and feeling for cool spots!!
Where are you as depending where in the world the tractor was destined for would determine which cooling packsge was fitted, temperate or tropical!!!
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
