Posted by old on August 06, 2013 at 09:55:20 from (209.86.226.11):
In Reply to: Miss fireing H posted by Alvin Dick on August 06, 2013 at 08:34:18:
That can be many things. Valves not set right or a bad rotor and or cap or bad distributor bushings etc etc. Check your spark at all 4 plug wires and make sure it is a good blue white and will jump a 1/4 inch gap or more. Also check that the points open to the same gap on all four lobes of the distributor
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
