Posted by 2 pipe on August 23, 2013 at 21:14:37 from (172.243.198.67):
In Reply to: Farmall M RPMs posted by James Williams on August 23, 2013 at 20:40:19:
Sounds to me like his governor bearings may be rusted up. Take the cover off the side of the governor and see if there is rust in there, if so sometimes you can take the bearings out and spray them with penetrating oil to loosen them back up. When you put it back together put some silicone or a new gasket on the cover.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
