Re: M Carb problems- Help!
Posted by ltf in nc on November 30, 2000 at 16:26:47 from (206.228.214.72):
In Reply to: M Carb problems- Help! posted by Doug on November 30, 2000 at 12:00:42:
Doug, If you are willing to do a little work try the following. IMHO the problem is in the clogged fuel line. This test will help identify the origin. This is a repeat of a previous posting from myself to others having the similar problem. Remove the plug that is in the carb bowl. Get a barbed fitting from a plumbing supply with the same thread size and a short piece of clear tubing that will fit the barb. Mount the new fitting in place of the plug and put the tubing on the fitting and turn the tubing vertically with the open end up and tie the tubing in place. This will let you see the fuel level that is inside the carb. When the tractor starts dying look at your "sight glass" to determine if the fuel is present or if it has disappeared indicating that from the needle/seat valve back to the fuel tank there is a problem. Post your findings.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
