Posted by mkirsch on September 03, 2013 at 11:57:35 from (64.80.110.75):
In Reply to: belly pump plumbing posted by BigTone on September 03, 2013 at 07:22:02:
TSC couldn't sell those hoses and fittings if they were not capable of whatever they're labeled.
The M isn't capable of anywhere near the ratings on those hoses and fittings.
Other than being a bit overpriced and limited on selection, the TSC hoses and fittings will be just fine.
The M was originally plumbed with plain old "black iron" pipe fittings. Modern machined hydraulic fittings may not work on the outlet ports coming through the frame of the tractor.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
