Posted by rosedale123 on September 21, 2013 at 16:43:44 from (108.224.113.216):
when i unhook the battery the tractor quits - is that correct? It has a 12 volt conversion using an alternator ( 3 wires) .From the spade connector one wire (#2) goes to the battery lug on the alternator. the other wire on the spade conector (#1) goes to the igniton swith. the battery lug on the alt ( I used 10 gage)goe to one side of the ammeter. the other side of the ammeter goes to the battery.
the ammeter needle does not "flinch" when the ignition is turned on and does not move when when the tractor is running. when running the battery voltage is 12.45. the battery voltage a the battery lug on the alternator is 12.45/
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
