Posted by jdemaris on September 21, 2013 at 17:06:47 from (70.192.13.104):
In Reply to: electical question posted by rosedale123 on September 21, 2013 at 16:43:44:
A fully charged battery with NO alternator charge is 12.7 volts. If the alternator is working, the voltage should be 13.8 to 14.2 volts. So yes, your alternator is not charging. You can bypass the voltage regulator if you want by sticking a pin in the back of the alternator into the "full field" port. If it starts to charge, it means the regulator is bad (A $12 item).
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
