Posted by old on September 21, 2013 at 18:55:43 from (209.86.226.19):
In Reply to: electical question posted by rosedale123 on September 21, 2013 at 16:43:44:
#1 doing that is not a safe thing to do because the alternator sees a dead battery and goes to max charge which in turn burns out the VR and that in turn makes itr put out 90 pl;us volts at 35 plus amps and if you got between the + cable and ground it can and will fry you as in your DEAD. Only way to check and alternator is with a volt meter. Be safe not DEAD or hurt. With it not running you should have around 12.3 volts on the battery with it running 13-14 volts. NEVER pull the battery cable to check an alternator it can cause you and the tractor big problems
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
