Posted by Janicholson on September 21, 2013 at 19:06:28 from (74.60.94.18):
In Reply to: electical question posted by rosedale123 on September 21, 2013 at 16:43:44:
Please don"t unhook the battery when running. The alternator (when working) becomes unregulated and can fry things with high voltage. (even fry You) It is a test with a generator, not an alternator. If full fielding it does nothing, the alternator is not working. If it does charge (assumes a good amp meter, or reading of 14 volts or so on the battery) the regulator in the alt may be bad. You state that the #1 terminal is connected to ignition. It should be passing through a marker bulb (NOT LED) on its way to the key. Or a 10 ohm resistor, or a diode with the band toward the alternator. Without this device in the wire (series) the engine will continue to run even with the key shut off. This light/resistor/diode device acts like an idiot light, and must be there. Jim
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
