Posted by soundguy on September 21, 2013 at 19:16:32 from (207.30.46.70):
In Reply to: electical question posted by rosedale123 on September 21, 2013 at 16:43:44:
in addition to the good info here.
I'd check the wiring onthe ignition switch.
for net charge / discharge.. ignition wire needs to be on the side of the ammeter as the charge device and all other loads.. with battery alone on the other side.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
