Posted by jimb2 on September 29, 2013 at 15:54:45 from (99.241.76.141):
In Reply to: IH 684 Brakes posted by StuartR on September 29, 2013 at 12:31:46:
Stuart, I am not sure this will fix your problem or not BUT IH installed the reservoirs on later models for a reason. CaseIH will want a small fortune for the parts likely. If you could get some tubing nipples and oil resistant tubing, you could make one out of a pint or quart motor oil container. It is a very difficult area to access.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
