Posted by mike van on September 30, 2013 at 02:54:31 from (24.151.25.186):
In Reply to: IH 684 Brakes posted by StuartR on September 29, 2013 at 12:31:46:
Stuart - I did a rebuild on the equ. valve on my 574, as I had the same problem, along with a fluid leak up in there. There is [was] a kit from IH for the equ valve, about 60.00 - To replace the valve was 700.00! People say JD parts are expensive, butI find they all are - Anyways, the kit did the trick, over two years now, I have brakes like when the tractor was new. Had to take out the battery, etc to get at it, but well worth it in the end.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
