Posted by D Slater on November 05, 2013 at 18:17:07 from (184.14.177.214):
In Reply to: mta fast hitch posted by LN on November 05, 2013 at 15:48:12:
SMTA, 400 and 450 transmission housings are the same. The fast hitch with traction control that IH started using in 1956 will fit all the bolt holes on a SMTA. Two point with traction control bolts in front to the same holes used for a swinging drawbar anchor for a standard drawbar. Other type 2 point has nothing mounted to the anchor holes.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
