Posted by gene bender on November 08, 2013 at 22:40:46 from (207.177.56.213):
In Reply to: farmall super c block posted by billie graham on November 08, 2013 at 20:08:31:
that serial3 is of the tractor and any "C" block will work. Where is the crack on the outside or inside between cycls also if its just on the outside it can be fixed easy with out welding and last for yrs so just where is the crack and how bad is it.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
