Posted by GRAPE-DRANK on November 09, 2013 at 10:43:42 from (98.117.67.240):
In Reply to: farmall super c block posted by billie graham on November 08, 2013 at 20:08:31:
There are a ton of serial number blocks that will work. The number 251069 354898 come to mind. They could say r1 r2 or maybe r3.
There are a ton of serial numbers that are compatible, some could be from stationary power units and the like.
Blocks from Super A, C, Super C, 100, 200, 130 & 230''s will all work and be a direct fit. Measure the bore diameter to make sure you order the right sleeves.
140 and 240 blocks have a different style water pump I'm not sure if they will work.
I don't know if the early thermosiphen Super A blocks are different with their water passages, it still wouldn't matter. The head gasket was different between thermosiphen and water pump. I don't know if there is a difference in the Super A head and a Super C head. The Super A governor spring is different than the Super C. That is the only difference I have been able to find.
I have built 1 Farmall motor and it's a hybrid from 3 differnent tractors. I meticulously chose every piece, went through 3 blocks. I used a 130 block, 140 crank and cam and a Super A head with a 3 angle valve job. Good luck and maybe you should call that fella that has blocks for sale.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
