Posted by JimB2 on December 08, 2013 at 13:58:30 from (99.240.243.222):
In Reply to: Re: IH 684 posted by TheRedState on December 08, 2013 at 11:28:58:
Hi, the transmission shift pattern determines if it is an early or late model 684. Both models have two transmissions a 4 speed, speed transmission and range transmission with Rev/Lo/Hi with one lever for each transmission. The only difference is the shift patterns. This gives 8F and 4Rev speeds as every speed transmission gear has Rev, Low and High speeds. The older models use a linear shift pattern. Speed transmission lever is 1-2-3-4 with 1 being at the rear with notches in the sheet metal guide. The range transmission is Rev at rear Neutral and Low straight down, High is down and towards the drivers seat. Newer shift pattern for speed transmission is H pattern with 1-3 at rear and 2-4 forward, Range transmission long lever is Rev to the rear, Neutral middle, Low straight forward, High to drivers seat and forward. There also maybe a T/A on the dash on left of steering column, looks like throttle control lever, forward is High (Direct Drive), towards drivers seat is Low. The T/A gives a shift on the go for every gear giving 16F and 8Rev speeds. Caution DO NOT pull T/A into Low will going down hill with a load behind tractor, also DO NOT pull T/A into Low while in 3rd or 4th High range with heavy load behind tractor. Shift T/A rapidly.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
