Posted by gene bender on December 16, 2013 at 11:10:21 from (207.177.56.213):
In Reply to: '42 H Just Won't Start posted by Farmer Matt on December 16, 2013 at 07:30:46:
Are you sure #1 is on compression sounds like you are 180 out on your dist just because the piston is at the top it mite be on exhaust instead of compression try again with plug out so you can tell its on compression
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
