Posted by 300dave on January 19, 2014 at 08:28:35 from (74.32.160.145):
I would like to get some opinions from you guys on how to proceed with this one. Recently bought at estate sale is 1-C175 engine out of a 350 utility machine. The machine went off for scrape. The engine is mounted in a engine stand. It is half way through a complete rebuild: that is Crankshaft tuned and over sized bearings installed. Rods installed with sleeves and pistons and rings ( all new). It sat this way for several years. There is light flaky rust on all the outside block surfaces. The inside off the block looks OK. Slight rust in the cylinder tops, but not pitted, rubs off. Also, rust in cam follower slots, etc. Gears for cam and crank have surface rust. I pulled cam shaft and it has surface rust on lobes, very minor; more of a stain, no pits. Crankshaft and pistons turn fine. Head is here and has been redone; greased and wrapped in plastic, new valves. Looks OK. Have all other parts in boxes. So, question is, where to go now. ?? How can I be sure that NO rust particles get in the oil and bearings? Would magnets in the oil pan work? Should I pull the sleeves and crank and have the block hot dipped? What is best way to be sure no rust chips get in and bind up the crank shaft? Especially down in those oil passages I cant see into. Any help here greatly appreciated. tx in advance dave
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
