If it were me I would pull the caps, crank, and pistons. Clean the block good just like you would for a rebuild. Clean everything like you are doing a rebuild and lube it. Blow out crank passages and reassemble. Basically do it just like a rebuild without putting in new parts. That gives you the opportunity to plasiguage things and verify the work.
You never know how much junk is in the assembly lube. There's no need to have it dipped as far as I am concerned, just do a meticulous clean and check the clearances on things. Cleaning it good also let's you check for cracks.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
