I filed and cleaned the points and it now fires! It'll run a little while when I dribble a little gas in the carb, but doesn't want to run from the carb and temporary fuel tank. Gas does run out the bottom of the carb when I pull the drain plug. I can rattle the float when I push it with a plastic tube through the drain hole. I'll be taking the carb off for a cleaning next.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
