Posted by Steve Reed (Mich) on April 19, 2014 at 15:27:06 from (99.54.88.140):
About two months ago I pulled the oil plug on the rear end of the Super C. When I did a bolt fell out. I just pulled the top off and found three bolts had fallen out and one plate that held the axles in place. I replaced the bolts added lockwashers and loctite. Putting the top back on I thought I had the forks all lined up. When I went to move it I found out I had no neutral, reverse in neutral and reverse. All four forward gears are locked up solid. Is it possible I put the reverse fork in the wrong spot? It does shift, but does not move. Thanks, Steve
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
