Posted by kub6040 on April 22, 2014 at 10:40:47 from (54.234.162.108):
In Reply to: Freeing a stuck motor posted by James Williams on April 22, 2014 at 05:45:08:
I have had good luck with acetone no atf . Once rust is loose enough to let by rings it will turn , at this time I use the 50/50 mixture until loose enough to remove parts that need replacing, if cylinders aren't bad you may still want to remove pistons and hone lightly
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
