Re: Freeing a stuck motor
Posted by NNP on April 24, 2014 at 06:00:24 from (66.66.112.196):
In Reply to: Freeing a stuck motor posted by James Williams on April 22, 2014 at 05:45:08:
another vote for fire. as many times as it takes.
in combination with the usual soaking, pounding, jack under a rod end, etc
doesn't really apply in this case, but I'd like to add, check everything.
Freeing up a badly stuck Farmall once.
usual methods failed, used fire repeatedly.
finally got to the point where I could swear all the stuck pistons were actually quivering when I whacked them.
(a usual sign that the individual piston is loose)
still stuck
Turns out that the big bushing on the governor/distributor
drive was also rusted stuck. was very tough to get loose without breaking the block.
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
